When exporting my corridor from OpenRoads Designer to a dwg or dgn, it connects the gaps between the linear features. For example, on the earthworks linear feature, it is connecting the cut features together and the fill features together.
I'm also getting similar results on the carriageway features, where they have been clipped across the slip roads. This is happening on both the 2D and 3D linear features.
Any ideas how to sort this out?
The release notes for ORD Update 3 seem to indicate this problem has been resolved. But it's still happening!!!!!
I think you need to have the two "Save application data" settings ticked in dwg export settings. A quick test of dgn SEEMED to be ok?
Mark
I can only find one "Save Application Data" setting.
yep, that's the one - but its not a real fix. If it is ticked, DWG exports opened in the Microstation environment don't have gaps joined. I checked in AutoCAD and the same DWG had the gap issue.
I can confirm the previous Merge to Master process now works without needing to drop anymore. Create a new DGN, reference in the model you want and turn levels you don't want off. Merging will give you a DGN without gaps and exports fine to DWG in MS and AutoCAD. They fixed something to do with string gaps, but not sure what?
