Is there a quick way to delete horizontal PI's in Update 2? I thought with update 2 there would be a reasonable amount of editing functions in the geometry section including being able to delete vertical PI's as well.
With complex redefine, I cannot replace a section of alignment that has multiple PIs with a single line.
Thanks!
To delete a PI use Delete Vertex
To redefine a complex the replacement element must be tangent to the complex you attempt to redefine. I managed to do it but it may be related to your geometry.
