Hi,I'm getting to grips with Superelevation Rule File and came across the difficulty. I need to calculate my superelevation using Rate Table rather than Rate Equation. The help talks about Rate Table but I can't see the option to create one inside the tool. Is it something to come in the future release or I'm missing something?Thanks,KrzysztofBtw. "Calculate Superelevation" section in help file seems to refer to SEP/SRL files...
Krzysztof
I believe we have been doing some work on this. I check on progress and feedback to you.
Simon Pegg
Bentley Civil Support
Simon, my question was whether it's possible to calculate superelevation from rate table rather than using equation. Thanks.
Simon,
Will join Krzysztof in this conversation. I hoped to import rate tables (Radius and required cross-fall assigned) from sup file. There is a tool, I struggled a little bit with sup file format but eventually got info that sup file was sucessfully imported - but waht and where to was imported I have noi idea, I think I lookd at every single possible place in superelevation tool and couldn't find imported rate tables. It looks to be a robust tool but I just need to have simple rate table and tranistion over the spiral length.
Adam
Is there any help/guidance on the use of Equation Editor?
