How can I disable the tool pop up shown below in the red box? So far I can disable it in the AccuSnap settings, HOWEVER I have to disable "identify Elements Automatically" AND "Pop-up Info". So see the pop up #2 not in the red box? The one that says "Line....Level:ab_MSE_Coping". I want to keep pop up #2 ON but turn the pop-up in the red box OFF.
Reason is, if I select something and the oppressive red boxed pop up shows up, I can not perform any commands such as the delete button on my keyboard, or any other keyboard commands until the oppressive red boxed pop up disappears by me moving my mouse away from it. There may not be an answer to my problem but please try to fix this in the software. Best regard!
Under AccuSnap Settings in the General Tab there is an option for pop-up info.
By default it is set to automatic you can disable it or change the behavior so the menu only appears when Tentatively selecting the element.
yes, I know. That doesn't really address what I'm asking. I'm saying: I have to disable both pop ups or enable both pop ups. I want to keep one enabled and disable the other.
There's a separate forum for Geopak (etc.). You might have more luck over there because that's an SS4/OpenRoads precursor tool, not found in regular Microstation.
While that pop-up can be useful, more often than not it gets in my way, too - blocking all my Accudraw input and shortcuts.
MaryB
I've got a similar problem (SS4 user) - did you ever find away to enable the microstation pop-up but disable the Geopak / SS4 pop-up?
