Hi all,
Does anyone have a good way to separate ORD sections from the ORD model? The issues I am having are:
1. Fatal error when I try to export to DWG
2. Replacement of text values with hashes (#) when I open them in Microstation CONNECT
3. Replacement of point labels to "NONE" if I export the section sheets only to V8 DGN
Ideally it'd be great to get the last method to work.
Mark
I had no annotations on this XS. However you will get them to "none" on export. In MSTN CE updt 7 there was no need to set the Visible Edges to Cached in Reference Dialog. Note, I exported XS to dgn and not dwg.
Every XS drawing's coordinates are set in the way that CL is at X=0.0 (Offset 0.0) and at Y=CL elevation so you can annotate this with normal XYZ tools. I will play with text favs maybe there is a way and we can avoid dropping the labels. Contractor requires all XS in a single drawing model and layput Top to Bottom - agian paingul to achieve with ORD.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Here is an explanation of Reference Visible Edge Display:
https://communities.bentley.com/products/microstation/b/microstation_v8i_blog/posts/newin-ss3-cached-visible-edge-display
Also a configuration variable can be set here:
