Is it possible to use multiple Linear Annotation Groups in one model to avoid unreadable alignment information?
Thanks in Advance
//Christiaan
You can assign each track a different feature definitions, then assign each feature definition a different annotation group and feature symbology to populate annotation on say the left side and right side of the alignments.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi Marcus,
This is way to complex and not user friendly:( in SS4 I can choose an annotation I want to add to the an alignment.
Please Bentley make it a change request that you can pick from a list any kind of annotation you want to use on a selected alignment.
I'll second that one.
We need ability to override Annotation Groups assigned to FD for sure.
eg. we have CL that is attached to detailed plans and to overviews. On detailed we get all elements along with stationing and other parameters annotate and on overview we just annotate major stations. Doable if you can change Annotation Group asigned to feature definition/symbology.
Try to do this when CL is approved on ProjectWise and can be opened as read-only. And this is common when we start drawing production. All design models need to be approved on ProjectWise.
Maybe Microstation Display Rules capability could be developed to enable such capabilitu to override annotation groups?
I've logged an enhancement request with development regarding this issue.
Enhancement request #807875 "Override Annotation Groups Assigned to Feature Definitions"
