When I use the "Change Level" icon in the Level Display tool box, all the levels are changed to OFF, not only the selected one.
There must be a variable to set somewhere , can anyone help ?
Hi Steven,
You can change the way this tool operates using the drop down in the dialog box:
The Display Off is controlled by the Key-In: levelmanager level offbyelem. You could try the key-in to see if you are getting a different result.
Holly
it was the Graphic Group lock that was on.
But when I close the DGN and open it again , the levels that I set OFF are ON again. I am working with ORD
Try doing a File > Save Settings before you exit.
thanks.
