Hi Bentley,
I had performed the horizontal design, vertical profile, carriageway design, rule-based superelevation, shoulder design and earthwork design on a MX Road model.
I found that the cut/fill line for the Right Hand Side of the design carriageway did not appear in the cross sections generated. The cross section only show till the verge of the RHS. However, the cut/fill line for the LHS appear in the cross section.
By checking on the plan of the MX Road model, the earthwork string with starting alphabet “I” was created.
By reporting the cross section string points, the cut/fill “IXXX” earthwork strings only appear for the LHS in the list. No “IXXX” earthwork strings for RHS show in the list.
May I know the method to solve this problem?
Thank you.
Hi Fredy, can you share the model.fil of the project? you can upload it here: https://bentley.sharefile.com/r-r241e6bcaa3d47628
Which version of MX do you have?
Hi, Marc. Thank you for your reply.
The model.fil of the project had been uploaded to the link you provided.
For your info, there are few models in the model.fil.
The problems for the cross section occurred in the model called "WP31R131B2" with "MCW1" master string name.
The triangulated ground model is named "TRG31G".
Actually, i had run the earthwork design wizard initially with template 1V:1H cut slope & 1V:2H fill slope for CH311000 to CH311200.
Then, followed by template 1V:1.5H cut slope & 1V:2H fill slope for CH311200 to CH312850 for earthwork design wizard.
However, the cut/fill lines for both RHS & LHS only appear in the cross sections for CH311000 to CH311200.
Whereas, the cut/fill line for RHS do not appear in the cross sections for CH311200 to CH312850.
The version of MX that i am currently using is MXROAD V8i (SELECT Series 4) with Build Number 08.11.09.789.
