OpenRoads Conceptstation - Import XML won't let you choose what template to use
Hi, in Conceptstation when you import an .alg file you can chosse what template you want to choose (rail, road and type).  But when you import an xml you can't.  The thing is when working with
Openroads Designer you can't export to .alg (or I did not find out how) so you have to export to an xml, open the xml in Inroads SS2 or others, save to an alg then open it with Concepstation.
Wouldn't it be easier if there was a way to import an xml and have the same option as an alg?
Parents Reply Children
