How can I create Vertical change in Profile from SS4 the same in ORD Plan Annotation the same for Speed annotations.
Thanks, Christiaan
Hi @christiaan, I have ran into a similar challenge and tried the work around proposed by Adam Wieczorek but it didn't work for me.
Can you please confirm if it worked for you, and how did you get it to work
The above instruction didn't work for me, did they work for you ?
I activated all check boxes, and applied the "with leader" option, but the annotation of the model in CAD only annotates horizontal elements and not vertical elements in plan.
