Is it possible to display K value on profile's parabola annotation multiplied by100 as it was possible in InRoads ? I am using R as a curve parameter and would like to annotate it also that way despite using parabolas.
Krzysztof Jędrych
Hi Krzysztof,
I wasn't able to insert a formula in the annotation but as a workaround I created a Text Favorite with the Parabola K Value and changed the Master Units to millimeters.
Answer Verified By: Krzysztof Jedrych
Yes, that is a proper method to do it. There should be centimeters because I wanted to multiply by 100 but the method is ok. Thank you very much:).
