After following the procedure to create a custom WorkSpace on the server and watching the corresponding video on doing so, I create a new WorkSpace, and a different config file is created. Not the config file that copied from the delivered Imperial Standards.cfg. Has this procedure change since the latest update?
Never mind. Found it.
https://communities.bentley.com/members/876a9d03_2d00_50fe_2d00_4eac_2d00_a39f_2d00_5b874baba676
communities.bentley.com/.../microstation-connect-workspace-template
