I'm still experiencing some issues when creating Field Books in the "Survey" working environment. I've created two videos showing my attempt from the starting point of creating a new workset and drawing all the way through creating my named boundaries, sheet sets and then, unsuccessfully my field book. Towards the end of the second video you'll see that I attempted to create a field book in the 3D view and it appears to create it but it never shows up in Explorer. It does appear though when I click on Delete Field Book. Please take a look at the two videos and offer any insights you may have on what I'm doing wrong. Thanks for your help.
I tried dragging and attaching the two videos here in the editor but apparently the file sizes are two large. I'll go ahead and post this message and then try to upload the files separately using the directions included in the Secure File Upload Wiki.
I tried sending the two video files per the secure file upload wiki directions and it said they successfully uploaded but for some reason they're not appearing in this post.
Does anyone have suggestions on how to attach two videos to this forum post that are approximate three to four minutes long each? I've tried drag and dropping them in to the editor as I was writing the original post and it said they exceeded the size limit. I then tried using the secure file upload procedure and this did not work either. Any other suggestions?
Post them on YouTube and put the links on your post.
Mark SegelquistKDOT CADD Administrator
GEOPAK user since 1990
"...the status quo is not a stream, let alone a 'mainstream'. It is a stagnant swamp. It is the innovators who carry mankind forward." - Ayn Rand
Yep post the Youtube link. I'm watching this topic pretty closely.
Thanks Cliff. I just finished uploading the two videos to YouTube. Here is the link to both.
https://youtu.be/GCHmzEb4jqA
https://youtu.be/SI-2ix6ZixM
Thanks for taking a look.
