Hello!
I am aligning catch basins to low points along an FOC profile. I have printed the profile to coordinate geometry and can see the stations for the low points.
My question is: Is there a way to have coordinate geometry generate these low points as elements in the microstation file that I can interact with?
In previous designs, I had an element in the microstation file that lined up with the FOC profile that I could basically set up an array along to put an element at the station corresponding to the low points. In this one, those paths are broken up and the array function no longer works.
Thanks for any help in advance!
What software are you using?
I am using Microstation V8i with Geopak V8i.
