Where do we find the Plan View Labeler in OpenRoads to label Sta. Offsets and other types of labels?
ORD is setup to annotated plan views in a drawing model. To annotate your design you need to create a drawing model from a named boundary. The software will attach your design model live nested and rotate it , so the 0 degree text will work. The problem now is you are working with a rotated and moved reference file. Unfortunately, Bentley really hasn't caught on to how much of a problem this can be for civil users.
See Post
https://mere-to-annotate-coordinates-stations-and-bearing-drawing-model-design-model-sheet-model
Yep, that may be the "solution" but it's an entirely unacceptable solution.
MaryB
How do I find a station? using something similar to DP OFFSET in Geopak.
Thank you.
You can use civil accudraw to place an element on a station.
