We are trying to use the linking code UD to set pipe inverts when our Surveyor shoots the top of casting - has anyone gotten this to work and can provide an example
We use our linking codes after the p-code separated by a space
We have tried SI[space]UD-6.5 and SI[space]UD[space]-6.5
We have set our linking code to UD and UD* neither of these has worked
Dan
Sorry one more item.
Before you import any data through FBK format verify the units issue has been resolved. See the link below:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/110966/fbk-import-to-open-roads-survey-version-ss4
Hope that helps.
Cliff
