Can someone explain to me what the settings under the Linking Code Feature Exclusions is used for
Dan
Some places in the world (not so much in North America) will not use linking codes but will instead connect a line between any points with the same code on consecutive points. If using this linking method then there are some codes you may wish never to be linked into a line, such as poles. You add any codes which should never be linked in the exclusion list. Since you are using linking codes then these settings are not relevant for you.
Robert Garrett Senior Consultant
www.envisioncad.com
Thanks Robert
PowerGEOPAK SS10 and ORD
Answer Verified By: Dan S
