Is there a special workflow to delete alignments or linear geometry from a drawing? It seems that anything with intervals - the remove interval function fails, delete doesn't work for plan view or from explorer. This really seems like a flaw in the program for it to be this hard to delete from files. It happens with alignments and linear geometry.
HI
Are you trying to delete the who piece of geometry ? Or just a part of it. /
Has the geometry got anything associated with it like a corridor template etc ?
How did you create the geometry in the first place/ using the OpenRoads tools or has it been imported from somewhere.
I am able to delete geometry using the Delete option in Explorer or using the pop up menus.
Simon Pegg
Bentley Civil Support
Generally im finding that deleting using the delete key doesnt always work but using the delete icon in the elements popup menu does - are you seeing this?
Mark
