hello dears i am beginner of power inroads have a question
1-civil tools imported surface (.xml) is not shown up in power inroads explorer surfaces why?
2-how i can show slope percentages with flow arrows when i import surface from civil tools using xml file or any other source?
3-where is low high points symbology located?
4-there are many of feature definitions like survey civil feature metric which are these have some link with preference files in power inroads explorer ? how i can setup all files linked to my design file?
5-if i will make some alignments, profiles surfaces from civil tools then will shown up or not in power inroads explorer? if not then why? the what is use of power inroads explorer?
6-which dgn libraries control element templates and which controls feature definitions?
thanks to all in advance
Answer Verified By: M Abrar
Thanks to reply so i have some more questions
1-you mean if i made some data like surface or geometry using civil tools and i want to use power inroads explorer features for that like slope vectors for surface or styles for aliments so i have to put feature deification applied on it to auto export so i can be shown up in power inroads explorer and we can use its features but 2 problems 1-i made one alignment its is not getting automatically a feature definition properties like level colors in my case geom-center line and if i auto export it to power inroads explorer in style manager there is no geom center line style is this because of it xin file that i geom center line is in civil feature metric.xin but in power inroads explorer there is civil.xin.... but from where my design file is showing civil feature metric.xin feature definition showing...and if it is attached to my design file then why not showig up in power inroads explorer??
2-look are my settings ok in in civil standards and element templates and power inroads explorer?
3-where are surface analysis like elevation analysis different elevation tables etc?
4-if i need some spot elevation on surface what i have to do?
5-i have seen videos also but mainly i am confused in link between .xin file, feature defination element template and .dgnlab
what controls xin file? only feature definition in project explorer? then why my feature defination toggle bar is showing two .xin files feature and power inroads explorer is showing 1 xin file attached?
i think you told dgnlab controls both feature defoliation and element template so if dgnlab is controling feature defination so xin file is controling what?
does element template controls only 3d like surface coridor properties and civil cells properties? many questions but that will be in next post i will tag you...thanks
