Hi all,
I would like to ask about how to export from OpenRoads file to IFC let say 2x3? Any ideas?
Maybe there is plug-in for that kind file transformation?
Guys, how do you manage with this inconvenience?
psz
In the Geometry ribbon, select Import/Export>Export Geometry then Export Type = IFC Alignment.
Thank you for the answer
So, we can export geometry to IFC. That's one small step for [a] man, one giant leap for mankind... but what about export corridor to ifc?
regards,
We use AECOSim to get IFCs out of ORD for now.
Not a very efficient Workflow, but the AECOSim IFC exporter works pretty well and is very customisable (based on my limited experience using it).
Just grab that module from AECOSim and put it in ORD - done ;)
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 16.3 | ProjectWise CE 3.4
Thanks Mark!
I'll check it out!
Kevin McDonald said:In the Geometry ribbon, select Import/Export>Export Geometry then Export Type = IFC Alignment.
It's interesting (but not good!) that a search for IFC in ORD help returns zero results...
Jan
