Select different workspace for Bentley Learn
Hi all. I'm trying to do some of the Bentley Learn tutorials and they require me to set the correct workspace.
The problem is, that my program (Power Rail Track SS4) has been set up by our CAD admin. The workspace that the program goes to by default is located on a network drive. This is all fine for working on different projects for clients, but I can't seem to get it to locate the workspace required for the learn tutorials.
I would like to keep the default workspace directory to the network drive, but also have a shortcut on my desktop that uses the correct workspace for the Learn tutorials. Is there a way to add a command to a shortcut so it does not load the workspace from the network drive, but the workspace located for the learn tutorials?
Parents Reply
  • Of course all of our CAD doctors are on vacation at the moment. For now I made a copy of my mslocal.cfg as backup, and modified the original from:
    %include msdir.cfg
    AT_VER_08_11_09 = 1
    #_USTN_WORKSPACEROOT : ${_USTN_INSTALLED_WORKSPACEROOT}
    _USTN_WORKSPACEROOT = R:/WorkSpace/
    MSDIR : ${MSDIR_INSTALLED}
    %include $(MSDIR)config/msconfig.cfg
    to:
    %include msdir.cfg
    AT_VER_08_11_09 = 1
    _USTN_WORKSPACEROOT = C:\ProgramData/Bentley/PowerRailTrack V8i (SELECTseries 4)/WorkSpace
    And it seem to have done the trick. I don't know if the "_USTN_WORKSPACEROOT" can be adjusted to include to paths, and I'm not sure I should mess about with it too much.
