Contours elevation
Hi!
How can I set the elevation ("Z" value) of contour lines that are sitting at the 0 zvale in 3D file (attached in the end of this question) using the OpenRoads Design CONNECT Edition tools. In the PowerInroads SS4 there was a tool called "Set elevation" or additional tools "ModZ" or "CivilTools" (both are not working in the OpenRoads). Is there a tool in the OpenRoads for setting the "Z" value of contour lines or any other element?
I'm aware of the tool "Profile By Constant Elevation" but this tool is slow and is not practical for setting the "Z" value of many contour lines.
2D situation (this is all I have to work with): situacija_pucisca_kupinovo_3D.dgn
