I am trying to use the Cross Section Sheet Composition tool with ProjectWise and receive the error "Unable to open sheet file pw:\path and file name". When using the tool I have the drawing open that contains the cross sections and the sheet dgn is read-write.
I have the option to detach existing sheet and place all sheets in active model. There is only one model in the drawing that contains the cross sections and the sheet drawing, both are design models.
Please help.
PowerGeopak V8i SS4 08.11.09.878
can you try and layout your xs in a new sheet file?
We created a brand new sheet file and still received the error message. I have attached a video to show the steps and the error.
Sean, thanks for the video. does it work with the files copied out? does it work outside the IDOT workspace?
It does work outside of PW using the IDOT workspace.
I would need to confirm here but it is looking like a defect. What version of projectwise? we just released a new update to powergeopak version 08.11.09.904, might be worth a try.
