In OpenRoads Designer, is there a setting to allow labels to be placed relative to the current view? Similar to how dimensions and notes have always worked in Microstation.
I am trying to place a label (station, offset) in a design model with the view rotated parallel to the alignment.
This still hasn't been fixed in 2021. The Label tool is almost useless with all the limitations (i.e., can't be placed in the model) and deficiencies involved (i.e., can't be placed in a rotated view). Please fix.
Another year goes by and still nothing.
Have you used Civil Labeler? I can place smart labels in model space with a rotated view no problem. Forget the label tool and use Civil Labeler.
I've briefly tried. Haven't had a chance to dig into the dialogs. I don't need the label to be dynamic to an alignment or element for the specific task I'm working on now, just "POINT 1", "POINT 2", etc.
I came across this issue. I was able to get what I wanted with the label when I turned off ACS plane lock in the drawing scales ribbon area
