ORD: Is there a way to change the right click default to the element selection tool instead of resetting the current command?
In Microstation SS2 the right click command ended the current command and defaulted back to the element selection tool. But in OpenRoads Designer and its multi-accept sequence the right click simply resets the command to the beginning. I would rather be able to "escape" the command using a right click instead of having to select the element selection tool at the top.
  • HI Derrik
    Yes I agree with your comment a bit painful when using the software all day long... Therefore I use a function key with "choose none" set to it. If you are using the Bentley default funckey.mnu for ORD this is already set on the F4 key. There are some other good ones in there also like open the template editor etc. I also added choose element to a function key to reduce my mouse movement...
    Ross
Reply
  • HI Derrik
    Ross
