Is there anyway to make custom assigned materials work with ProjectWise?
Hi!
A customer wanted to have a elevation profile along with a table with different rock parameters constructed along tunneling system we've created in InRoads.
Roughly setup in InRoads the project looks like this:
We figured the easiest way to make this was to create table and profile in 2D and print out a png, which we would then assign as a material on a surface behind the tunnel system.
The problem is that the materials need to be extracted as a local copy along with the DGN for it to work.
Is there anyway to make assigned materials work with ProjectWise for example? Without having to assign the materials again.
We want everything to be included in one file. A 3D-pdf was not good enough and an i-model did not work any better.
Would love some input on this topic.
Kind Regards
Lucas
