Hi all,
I would like to know if it is possible to bring 3D geometric information from linear utilities (designed with SUE workflow within OpenRoads Designer) into AECOsim Building Designer.
I mean the whole volume information and not just its layout as a 3D linear entity.
In the first image I can see 3D data in SUE which I would like to maintain back in AECOsim (in the second image I've lost volume data from the conduit whereas the inlet has been properly transferred). I've just opened the DGN from OpenRoads Designer into AECOsim; I don't know if there would be a better workflow to do this.
I would appreciate any suggestion or help!
Thank you
Aitana
We are also getting this issue. We are using AECOsim to build a federated models, and cannot see the 3d conduits or manholes.
Was this ever resolved? Did you find a work around for this? I'm having the same issue.
I would suggest referencing in the SUE/OpenRoads model, instead of opening it directly in OpenBuildings/AECOsim. Make sure you reference in the 3D model, not the Default 2D model.
The only way I've found is to publish i.dgn from ORD this publishes all data to the objects which when left as dgn is maintained in the civil data which can't be read by AECOsim
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
