I'm trying to export alignment (horizontal + vertical). Has anyone been successful with exporting alignment to either MX genio or LandXML? Regardless to which version I export, XML file is empty whereas genio file looks like this:
DELETE TNH OPTION 4 CREATE TNH OPTION 4 GENIO TNH OPTION 4 017,NORM
Any advice would be appreciated. Thanks.Regards,Krzysztof
Unfortunately also happens to me intermittently on different occasions. I would love to know what the trigger is???
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Krzysztof,
Like Mark,I've seen this intermittently.
I'm trying to ifnd out if there's a specific type of geometry which causes it.
I have had it working. There must be a specific workflow which causes it, but I haven't trakcked it down yet.
Simon Pegg
Bent;ey Civil Support
I have this issues as well; XML is empty.
Has anyone found a solution?
One thing to check is - has the vertical alignment got a name?
Yes, vertical alignment has a Feature Name.
Thank you for the suggestion though.
