I updated the point names on some templates and after synchronizing the template, the corridor models correctly however the previous point name and complex element still exists in the drawing. So I'm left with multiple slope stake lines throughout the corridor. I've tried Process Corridor and that doesn't help. Any other ideas?
Hi TN,
I duplicated your workflow in one of my dgns, and didn't see elements with the old template names in my dgn. Have you crashed in this dgn or received any error messages? If you try this workflow in a brand new dgn, do you see the same old template names with the update ones? There may be something specific to this dgn that is causing a problem. If you attach the dgn and all the reference files, I can take a look for you to see if there is a problem in the dgn.
What version of ORD are you using?
Holly
I'm on Update 2 of OpenRoads Designer CONNECT. I've tried to redo the corridor and the same issue arises with multiple slope stake lines. It seems like the file has gotten corrupted so I'll do a test in a new file.
Have you tried the repair relationship tool in the Civil Display Browser command key-in? I have had the same issue and doing this fixed it.
