Is there a reason annotation works for some cross sections but not others even when the template point names are the same. When managing the annotation group for the cross sections, the points are highlighted in the preview. Some annotation displays but it's not consistent. Each of the side slopes is highlighted in the manage window as well but maybe 50% display.
Additionally, when you have multiple corridors, is it best to split up the named boundaries and cross section models by corridor?
Thanks!
You will first want to make sure that the points are added at the bottom of the dialog to be filtered through the filter you are using. Either have them added, or keep the filter completely blank. Then create the expression that you want for the filter. If you just want points with two specific Feature Definitions then do something like "Feature 1" OR "Feature 2". Be sure to use an OR and not AND. A point cannot have two Feature Definitions.
