Is there a way to export the slope stake lines from a corridor to clean up for final production. Copying them into a blank dgn doesn't work cleanly.
Are there any quick fixes for the gaps that occur between different slopes and cut/fill?
Thanks!
(Update 2 - OpenRoads Designer)
I make sure to use a feature name override for all cut and fill points and components. With the same feature name override, cuts and fills in the same corridor will join up and close any small gaps.
Mark
