How to split a large file loaded from XML to load them in PowerCivil?
I am building terrain models in PowerCivil but some XML are too large, therefore I am trying to split the XML in OpenRoads and then opening them as separate so PowerCivil can handle them.
Thanks.
  • EDIT: SOLVED, it was with EXTERNAL CLIPPING.
    I created few shapes and 'Clipped Terrain Model (Element)', when extracting each Clipped Terrain Model (internal clipping) to XML, it is considering all the model or the sections taken are not well represented when importing XML terrains in PowerCivil.
    I would like to split the model, so I can load the content of every shape as separate Terrain Model in PowerCivil.
    Any ideas? Thanks!
    OpenRoads Rectangular Shapes for ClippingPowerCivil importing XML is not showing the terrain properly
