[OpenRoads Designer CONNECT] Obsolete civil data found in design file
Hello guys,
We are in the process of migrating our users and projects to OpenRoads Designer CONNECT Edition.
We are currently using the following products:
Microstation V8i - SELECTseries 3
GEOPAK Civil Engineering Suite
There is a known issue when attempting to load an existing SS3 design file into OpenRoads CONNECT.
One is presented with the following dialog:
I went ahead and created a blank design file using our default seed file.
When I load this file into ORD I still get the same warning message.
What exactly is this obsolete civil data? Where is it located?
Is there a way to safely remove this data by means of a macro or application?
If it cannot be removed then I see no way at the moment to migrate an existing project to ORD.
Any suggestions would be greatly appreciated.
Benzi
