Hello. I need construct an arc between two fixed arcs.
The commands that allow me to build a free arc, draw the spirals associated with that arc, but they do not draw the inverse spirals associated with the fixed arcs.
How can I get it?
Thank you.
Use the complex transition between any element and arc tool. This gives the option to specify a leading and trailing transition.
Hi. I get the leading and trailing transition in the ahead element. But i don't get this in the back element. See figure.
This button let me choice "Double Spiral" in ahead, but don't let me this in back element.
I need the four spirals, but i don't get the first.
Thank you
Use the Arc Between Arcs command. This should give the option of a reverse curve, and then you can specify the leading and trailing transitions.
