Issue:
In ORD Update 2, I get the below error when using Export Geometry, Export Type: MX Genio
Workflow:
Openroads Modeling > Geometry > Export Geometry > MX Genio
Any help would be greatly appreciated. Thanks in Advance.
We had this issue installing ORD on our Windows 7 machines. You'll need to install Microsoft Visual C++ Redistributable on your machine - do a quick Google search for the correct version.
Cheers,
Mark
Answer Verified By: Colin H
Works now. I had to install the 2017 version of Microsoft Visual C++ Redistributable. Thank you for pointing me in the correct direction
