Hi All,
I am trying to create an arc tangential at one end to a circle, ending at a random point, this is the result, close to what I want:
When I specify the exact radius (either during arc creation process or after), it just jumps to alternative tangential point on a circle:
Is it a bug or can I obtain alternate result? Can't see any option for that.
Tried on MX and ORD v. 10.02.00.60 and I'm getting the same result.
Also, I was trying to work around it using Arc Between Points with a Tangent snap to a circle, resulting in a crash.
Tried it many times, as I could not believe it hangs on that, but it does, both packages, every time.
Any help/explanation would be welcome.
Kind regards, Tomasz.
Hi Tomasz,
Can you please tell me the exact tool you are using in ORD and how you implement it? I used the Arc Between Elements command to recreate the first picture you show. It created a curve that is tangent to the circle. Have you tried this method?
Holly
Hi Holly,
Thanks for digging, Tomasz.
I create Enhancement 868432: Arc to Element: Choose which side of circle to declare tangency for development to review your request for future releases of OpenRoads Designer. As a workaround, I recommend drawing an element to represent your end tangency. Then use the Simple Arc Between Elements to get a concave curve that terminates tangent to the bottom half of the circle you show in your screenshot.
Tomasz, have you tried the SHIFT key, after specifying the end point. This sometimes offers an alternative solution.
Tried just now to no avail. Thanks.Even if it worked during edit, that would still leave the problem of an arc jumping to a different tangency solution after placement the moment I amend radius.
