I have loaded a .tin file.
On the DTM toolbar menu Utilities there is a option to ExportMX.
When I do, I get an Information window:
Can not load vba project [C:\Program Files (x86)\Bentley\XM\Geopak\V8.9\bin\GeopakMx]
Is there any way to save out my tin model as a MX model?
David
Hi David,
for the tool to function, you need to have MX installed on your machine AND you need to have an existing MMD file to import the TIN into.
The tool is calling MX dialogs and, unless MX is installed, the dialogs cannot be found. Hence the VBA error message.
If you have MX installed and a MMD file already created... please contact me directly and we can take a look.
If you use the export to LandXML option (that is also available on the tool), whoever needs the data in MX will be able to import that XML file into their MX project.
