Is there any documentation on how to use this report in GEOPAK SS4? I want to be able to report, at an even 25' interval, the Station, Offset and Proposed Elevation along the roadway corridor. Can anyone provide me with some information on how to create such a report?
Brad Lund
Hi Brad,
If you have the Bentley Civil Report Browser open, you can right click on the xsl report you want to know how to use and click Style Sheet Help. This will pull up a window describing what is required to populate the report. If you want to create a report of a Proposed Elevation along the corridor, I recommend creating a Terrain from the Corridor then running the Report tool.
Holly
I am needing to create a "paving grades" report that would be similar to what you are talking about here. I am using ORD Update 3. I have created a terrain that represents my pavement surface. I do not see a way to create a report that would list the elevations of the breaklines every 25 feet along the alignment. Do you have any more info on how to do this?
Tom SawyerIT Business System Analyst SupervisorBusiness Technology Support DivisionNebraska Department of TransportationThomas.Sawyer@Nebraska.gov
I am still unclear as to how to create such a report. I've also got a proposed surface, but I don't see anywhere you can create a report to give you a station and offset from an alignment and a proposed surface? Can anyone please provide more details on how to do this?
Creo q este es un tema recurrente, necesitaríamos una respuesta definitiva o un ejemplo, por favor
