Is there a way to set default symbology settings in the various symbology dialog boxes?
If the symbology is changed by the designer, is there a way to insure they stay as changed within that design?
Microstation 08.05.02.35
Geopak 08.08.03.24
Thanks, Bob Mullenix
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
Bob - I don't know the answer to your question, exactly. Have you tried using the D&C Manager with the place influence check mark turned on? By doing this, all you have to do is pick the design feature you want and the symbology takes care of itself.
Neil - IN addition to the above, all you have to do is set the Microstation active color, weight and style to bylevel and then all that has to be adjusted is to change the active level. In addition, since you are a PowerCivil user, you can set the variable GPK_LEVEL_SET_BYLEVELS = 1 and all the Geopak/PowerCivil symbology boxes will function the same way. IE all you do is choose the level and color, weight, style are always bylevel.
Robert GarrettSenior Product EngineerBentley Systems Inc.
The above dialog box is what I'm refering to. There are a few similiar to this within the project manager process.
Would like to default this to Level = P_GEOPAK_PETTERNLINES_DESIGN, Color = 1.
Even after changing and using this dialog box, the symbology is not saved. Bob
Bob - I've been away from road design for a while now so take the following as "suggestions" and not abolute gospel.
First I would have expected that after the first use of the dialog that the symbology would be preserved and retained the next time you open it. I'm sort of guessing because I just don't remember. If they are intended to be preserved then they would probably be stored in a RSC file. Are the other dialog entries being preserved between uses of the tool? If yes then then things are probably working as designed. If no, then maybe there is a problem with your RSC files. In Windows Vista, in particular, you need write access to the bin directlory to properly create the RSC files.
Second, are you using Project Manager? If yes, then be sure to define the values for pattern lines in the project run which should populate the dialog when it starts.
If these suggestions don't help, then Derricke should be around soon and can probably better address your question.
