Whenever I pull my vertical alignment below existing grade, the conceptualized roadway is masked by the existing ground and imagery. Shouldn't it show a conceptualized cut situation?
Quinten,
It should, do you have cut/fill end conditions in the template you are using?
Tom F
I do, I even double checked that. It doesn't matter if its a Bentley created template or one that I created.
Here is a screen shot of what it is doing. I just recreated this and it immediately did it from the best fit profile.
Do you have one road crossing another? This will affect the clipping. Removing the overlap (or creating intersections and ramps) should clean this up.
