Is it possible to one feature definition with 2 alpha codes? If so how do I set it up. I tried entering the 2 alpha codes separated by a comma but that did not work. I have 2 survey point codes (alpha codes) that I want to use the same feature definition. I am using InRoads SS3.
You should be able to set a feature definition with multiple alpha codes separated by a comma. Try entering in the multiple codes on the feature definition, separated by a comma but without a space.
I don't believe this would be a limitation in SS3 as the survey functionality should have carried up, but I guess it is a possibility. I am working in the latest SS4 version 08.11.09.878.
Answer Verified By: Dalek
Dale
Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
Drug kicking and screaming into the world of InRoads & ORD!!
