We have a user trying to make some changes to a project using OpenRoads (SS4). He's having an issue where when the corridor processes anything, even a very minor change it takes minutes. He remembers processing taking sometime previously but nothing like this. Anyone from the Bentley Communities has any suggestion's to speed this up? He makes most of the changes at once and then let it process them at once, but it behaves the same way if he makes a single change. It sometimes crashes before completing the processing, but don't know if that is related or just typical OpenRoads.
Take a look at: www.youtube.com/watch
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Thank you, Adam.
