In all the tests that I have done, the progran doesn´t recognize as a target aliasing the corridors that are within references.It only recognizes corridors in the main file.
I need to be able to recognize the corridors in references.
Is this possible?
ORD update 2
Select the component that you are trying to target rather than the corridor. Add that component as a corridor reference then it will show up at the very bottom of the target aliasing list.
I think Jeffrey may be referring to the Corridor Referencing tool under Corridors > Miscellaneous on the Ribbon. You can add Corridor "References" there that are not Reference File attachments. This tool has you select the design meshes of adjacent components from a MicroStation referenced corridor. From there, you can use target aliasing to define as Jeffrey mentioned in the next post.
