I just installed the new OpenRoads Release 3 (10.03.00.43) and tried to then open an old InRoads SS4 design file. Instead of opening, I get the following error message:
The Civil Data [V8i (SELECTSeries 4)] found in this file is not supported by OpenRoads Designer Connect Edition. Would you like to open the file Read-Only?
I thought this new release was going to have the ability to open older InRoads files? Is this not the case?
I am wondering the same thing myself. The "What's New" file for this release states the following: Project upgrade of Civil (SELECTseries 4) data to OpenRoads Designer Update 3 (Technology Preview) .
However, I cannot find any additional information about this, or figure out how to get it to work.
Hi guys,
I got it to work by adding CIVIL_UPGRADE_PROMPT_OFF = 1 to my workspace cfg. Took me a while to figure it out!
Answer Verified By: Chris Booth
Thanks Mark for sharing this. You spent a while on that, and saved a while for others here.
Thanks Mark. That's great information and worked for me. I agree with Adam, you save a lot of us some time. I've only opened one SS4 file in ORD and I tried to create a profile view from an alignment that was in the file and it seems to not recognize it as an alignment anymore. It's just recognizing it as a complex element. I'll have to play with the SS4 file more to see how well it's working in ORD.
Sorry, I forgot that the alignment had to be in the active file your working in. I had it referenced in to the SS4 file I had opened in ORD.
