net framework error
when trying to place a civil cell in Power Geopak SS4 I now get this error message, It was working fine till I had Adobe Pro DC loaded on my computer. I have hade adobe and Power Geopak remove and I have reinstalled Power Geopak, but I still get this error. Any suggestions to fix this would be appreciated,  The following a detailed printout of the error.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
Parameter name: key
   at System.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at Bentley.Civil.Geometry.Model.CivilCell.CopyContext.ReferenceList..ctor(CivilCell civilCell)
   at Bentley.Civil.Geometry.Model.CivilCell.CopyContext..ctor(IObjectSpace sourceObjectSpace, IObjectSpace targetObjectSpace, CivilCell sourceCivilCell)
   at Bentley.Civil.Geometry.Model.Commands.PlaceCivilCell.CivilCellNamedObjectEntry_EntryChanged(Object sender, NamedObjectEntryDescriptorEventArgs e)
   at Bentley.Civil.UI.Commands.NamedObjectEntryDescriptor.EntryValueChanged()
   at Bentley.Civil.UI.Commands.EntryDescriptor.DoEntryValueChanged()
   at Bentley.Civil.UI.Commands.NamedObjectEntryDescriptor.SetValue(Object value, Boolean fromDelegate)
   at Bentley.Civil.UI.Commands.ManagedCommand.SetValue(String key, Object value, Boolean fromDelegate)
   at Bentley.Civil.UI.Commands.ECPropertiesFactory.SetNamedObjectEntry(Object instanceData, Object propertyData, Int32 arrayIndex, IECPropertyValue propVal, NamedObjectEntry value)
   at Bentley.Civil.UI.Commands.LightweightNamedObjectEntryType.SetNativeValue(Object instanceData, Object propertyData, Int32 arrayIndex, IECPropertyValue propVal, Object value)
   at Bentley.Civil.Geometry.Model.Commands.PlaceCivilCell.CivilCellEntryDescriptor.SetNamedObjectEntry(Object instanceData, Object propertyData, Int32 arrayIndex, IECPropertyValue propVal, CivilCellObjectEntry value)
   at Bentley.Civil.Geometry.Model.Commands.PlaceCivilCell.LightweightCivilCellEntryType.SetNativeValue(Object instanceData, Object propertyData, Int32 arrayIndex, IECPropertyValue propVal, Object value)
   at Bentley.ECObjects.Lightweight.LightweightValue.set_NativeValue(Object value)
   at Bentley.ECObjects.UI.ECMultiInstancePropertyAdapter.PrimitivePropertyDescriptor.SetValue(Object component, Object value)
   at Bentley.Civil.UI.Controls.TypeEditorControl.set_Value(Object value)
   at Bentley.UI.Controls.WinForms.TypeEditorControl.InitializeControl(PropertyDescriptor propertyDescriptor, Object defaultValue)
   at Bentley.Civil.UI.Controls.TypeEditorControl..ctor(PropertyDescriptor propertyDescriptor, Object defaultValue)
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.CategoryPanel.AddControlsForPropertyValue(TableLayoutPanel container, PropertyDescriptor pD, Int32 propertyCount)
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.CategoryPanel.ConfigureComponent(ICustomTypeDescriptor typeDescriptor)
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.CategoryPanel..ctor(ICustomTypeDescriptor typeDescriptor, String title, CatagorisedECControlCollection parent)
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.CreateCategoryPanel(ICustomTypeDescriptor type, String title)
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.InternalSetInstanceListSet()
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.ReloadInstanceLists()
   at Bentley.Civil.UI.Controls.CatagorisedECControlCollection.OnReloadTimeout(Object sender, EventArgs eventArgs)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8762 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Bentley.PowerPlatform.FeatureAspects
    Assembly Version: 1.0.0.0
    Win32 Version: 08.11.09.878
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Bentley.PowerPlatform.FeatureAspects.DLL
msvcm80
    Assembly Version: 8.0.50727.6195
    Win32 Version: 8.00.50727.6195
    CodeBase: file:///C:/windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a/msvcm80.dll
Bentley.PowerPlatform.FeatureAspects.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PowerPlatform.FeatureAspects.resources.DLL
ustation
    Win32 Version: 08.11.09.832
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/ustation.DLL
Bentley.General.1.0
    Win32 Version: 08.35.01.06
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.General.1.0.DLL
msvcm90
    Assembly Version: 9.0.30729.6161
    Win32 Version: 9.00.30729.6161
    CodeBase: file:///C:/windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
System
    Win32 Version: 2.0.50727.8770 (QFE.050727-8700)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Bentley.MicroStation.Interfaces.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL
Bentley.MicroStation.XmlObjectModels
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.XmlObjectModels.DLL
System.Xml
    Win32 Version: 2.0.50727.8773 (QFE.050727-8700)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.ApplicationBlocks.ExceptionManagement.1.0
    Win32 Version: 01.00.00.01
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL
Bentley.DialogManager
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DialogManager.DLL
MdlSeed
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/MdlSeed.DLL
System.Configuration
    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
DetSymbEnabler
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/DetSymbEnabler.DLL
Bentley.Designlinks
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Designlinks.DLL
Bentley.ECObjects.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECObjects.2.0.DLL
Bentley.UI
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.UI.DLL
componentset
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/componentset.DLL
Bentley.ECSystem.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECSystem.2.0.DLL
Bentley.EC.Persistence.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Persistence.2.0.DLL
Bentley.Platform
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Platform.DLL
Bentley.EC.Controls.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Controls.2.0.DLL
Bentley.logging-2.0
    Win32 Version: 08.11.04.09
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.logging-2.0.DLL
Bentley.Exceptions
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Exceptions.DLL
markup
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/markup.DLL
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.DLL
Bentley.ECXAttributes
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECXAttributes.DLL
Bentley.Geometry.Common.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Common.1.0.DLL
mptools
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mptools.DLL
Bentley.DesignlinksHandler
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/Bentley.DesignlinksHandler.DLL
Bentley.Civil.Loader.MicroStation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Loader.MicroStation.3.1.dll
Bentley.Civil.BCSystem.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.3.1.DLL
Bentley.Civil.CadSystem.Interfaces.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Interfaces.3.1.DLL
Bentley.Civil.Objects.Presentation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Presentation.3.1.DLL
Bentley.Civil.Objects.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.3.1.DLL
Bentley.Civil.Geometry.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.3.1.DLL
Bentley.Civil.Geometry.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.3.1.DLL
Bentley.Civil.Formatting.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.3.1.DLL
Bentley.Civil.Geometry.Microstation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Microstation.3.1.dll
Bentley.PropertyManager
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PropertyManager.DLL
Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1.DLL
Bentley.Civil.Geometry.Linear.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.3.1.DLL
Bentley.Geometry.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.2.0.DLL
Bentley.MicroStation.Templates.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.Support.DLL
Bentley.MicroStation.WinForms.ECPropertyPane
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL
Bentley.MicroStation.MaterialControl
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.MaterialControl.DLL
Bentley.MicroStation.WinForms.Controls
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL
Bentley.ECObjects.2.0.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECObjects.2.0.resources.DLL
System.Runtime.Serialization
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.4506.8789 (QFE.030729-8700)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Bentley.PropertyManager.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PropertyManager.resources.DLL
MRMesh
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mrmesh.DLL
Microsoft.VisualC
    Assembly Version: 8.0.0.0
    Win32 Version: 8.00.50727.4927
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
Bentley.ECXAttributesAddIn
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.ecxattributesaddin.DLL
Bentley.Properties.ElementHandlerPropertiesEnabler
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Properties.ElementHandlerPropertiesEnabler.DLL
Bentley.PointCloud
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PointCloud.DLL
bentley.designexplorer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.DLL
bentley.designexplorer.elementexplorer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.DLL
Bentley.RasterPropertiesEnabler
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterPropertiesEnabler.DLL
Bentley.PointCloud.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PointCloud.resources.DLL
Bentley.DesignlinksApp
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DesignlinksApp.DLL
Bentley.MicroStation.General
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.General.DLL
Bentley.DesignlinksApp.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DesignlinksApp.resources.DLL
kmlplacemark
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/kmlplacemark.DLL
Bentley.PointCloudAdv
    Assembly Version: 8.11.9.720
    Win32 Version: 08.11.09.720
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Descartes/assemblies/Bentley.PointCloudAdv.dll
Bentley.ExpressionEvaluator
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.expressionevaluator.DLL
Bentley.DGNECPlugin
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.DLL
Bentley.DGNECPlugin.Common
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.Common.DLL
Bentley.EC.AbstractUI.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.AbstractUI.2.0.DLL
Bentley.ECUISupport
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECUISupport.DLL
Bentley.Civil.CadSystem.Microstation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Microstation.3.1.dll
Bentley.Civil.Graphics.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Graphics.3.1.DLL
Bentley.Civil.CadSystem.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.3.1.DLL
Bentley.Windowing
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.DLL
Bentley.Civil.Model.MSPlugIn.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.MSPlugIn.3.1.dll
Bentley.Civil.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.3.1.DLL
Bentley.Civil.Objects.RuleManagement.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.3.1.DLL
Bentley.Civil.Objects.Data.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Data.3.1.DLL
Bentley.Civil.MicroStation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MicroStation.3.1.DLL
Bentley.Civil.Microstation.Utils.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.Utils.3.1.DLL
Bentley.Civil.DTM.3.0
    Win32 Version: 08.11.09.396
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Civil.DTM.3.0.DLL
System.Drawing.Design
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
Bentley.DTM.Element
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DTM.Element.DLL
Bentley.Civil.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.3.1.dll
Bentley.Civil.Applications.GPSTrackExt.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.3.1.dll
Bentley.Interop.MicroStationDGN
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Interop.MicroStationDGN.DLL
Bentley.GlobalPosition
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GlobalPosition.DLL
Bentley.GeoCoord
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GeoCoord.DLL
Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1.dll
Bentley.Civil.Applications.Survey.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.3.1.dll
Bentley.Civil.Applications.Survey.Objects.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Objects.3.1.DLL
Bentley.Civil.Applications.Survey.COM.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.COM.3.1.DLL
Bentley.Civil.UI.Commands.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Commands.3.1.DLL
Bentley.Civil.UI.Controls.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Controls.3.1.DLL
Bentley.Civil.Objects.UI.Controls.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Controls.3.1.DLL
Bentley.Civil.Geometry.Model.Accessor.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Accessor.3.1.DLL
Bentley.Civil.DomainModel.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DomainModel.3.1.DLL
Bentley.EC.Presentation.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Presentation.2.0.DLL
Bentley.Civil.Applications.Survey.Microstation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Microstation.3.1.DLL
Bentley.Civil.ProjectSettings.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Model.3.1.DLL
Bentley.Civil.UI.Templates.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Templates.3.1.DLL
Bentley.Civil.Geometry.Model.Commands.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Commands.3.1.DLL
Bentley.Civil.Applications.Survey.Settings.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Settings.3.1.dll
Bentley.Civil.BCSystem.Base.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.Base.3.1.dll
ElementInfo
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/ElementInfo.DLL
Bentley.Civil.Commands.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Commands.3.1.dll
Bentley.Civil.Geometry.Command.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Command.3.1.DLL
Bentley.Civil.Model.UI.ContentManagement.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.ContentManagement.3.1.DLL
Bentley.Civil.GraphicalFilters.Presentation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Presentation.3.1.DLL
Bentley.Civil.GraphicalFilters.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Model.3.1.DLL
Bentley.Civil.DTM.TextImport.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImport.3.1.DLL
Bentley.Civil.Geometry.Services.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.3.1.DLL
Bentley.Civil.DTM.ImportExport.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImportExport.3.1.DLL
Bentley.Civil.ConsensusModel.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.3.1.dll
Bentley.ECExchange
    Win32 Version: 08.35.01.05
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECExchange.DLL
Bentley.DesignSync.DesignViewer
    Win32 Version: 01.10.01.01
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DesignViewer.dll
Bentley.DesignSync.Interfaces
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.Interfaces.DLL
Bentley.DesignSync
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DLL
Bentley.GeometryStructsNET1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.GeometryStructsNET1.dll
Bentley.DgnPlatformNET
    Win32 Version: 01.10.01.06
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DgnPlatformNET.dll
Bentley.Civil.ConsensusModel.SDK.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.SDK.3.1.dll
Bentley.Civil.ContentManagement.Geopak.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.Geopak.2.0.dll
Bentley.Civil.Model.Handlers.ContentManagement.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.ContentManagement.3.1.DLL
Bentley.Civil.ContentManagement.MS.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.MS.3.1.DLL
Bentley.Civil.CoreCommands.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CoreCommands.3.1.dll
Bentley.Civil.DesignStandards.Presentation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DesignStandards.Presentation.3.1.dll
Bentley.Civil.Model.Handlers.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.3.1.DLL
Bentley.Civil.DTM.Extension.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Extension.3.1.dll
Bentley.Civil.DTM.ImagePP.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImagePP.3.1.dll
Bentley.Civil.DTM.LinearGeometry.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.LinearGeometry.3.1.dll
Bentley.Civil.DTM.Services.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.3.1.dll
System.ServiceModel
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Bentley.Civil.DTM.Services.Civil.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.Civil.3.1.dll
Bentley.Civil.DTM.Services.NUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.NUnit.3.1.dll
Bentley.Civil.DTM.TextImportProvider.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImportProvider.3.1.dll
Bentley.Civil.DTMGraphicalFilters.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Model.3.1.dll
Bentley.Civil.DTMGraphicalFilters.Presentation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Presentation.3.1.dll
Bentley.Civil.EditTM.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.EditTM.3.1.dll
Bentley.Civil.Formatting.Microstation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.Microstation.3.1.dll
Bentley.Civil.Geometry.Coordinates.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Coordinates.3.1.dll
Bentley.Civil.Geometry.DesignStandards.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.DesignStandards.3.1.dll
Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1.dll
Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1.dll
Bentley.Civil.MSNUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.3.1.DLL
Bentley.Civil.Geometry.Linear.ECXML.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ECXML.3.1.dll
Bentley.Civil.Geometry.Linear.MSNUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.MSNUnit.3.1.dll
Bentley.Civil.Geometry.Linear.NUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.NUnit.3.1.dll
Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1.dll
Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1.dll
Bentley.Civil.Model.ContentManagement.Management.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.ContentManagement.Management.3.1.DLL
Bentley.Civil.Geometry.Model.MSNUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.MSNUnit.3.1.dll
Bentley.Civil.Geometry.Model.SnapRules.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.SnapRules.3.1.dll
Bentley.Civil.Geometry.Presentation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Presentation.3.1.dll
Bentley.Civil.Model.UI.Geometry.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.Geometry.3.1.DLL
Bentley.Civil.Geometry.Services.Civil.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.Civil.3.1.dll
Bentley.Civil.Geometry.Services.GEOPAK.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.GEOPAK.2.0.dll
Bentley.Civil.Geometry.Services.LandXML.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.LandXML.3.1.dll
Bentley.Civil.Geometry.VCAdapter.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.VCAdapter.3.1.dll
Bentley.Civil.Geopak.Services.Geometry.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.2.0.dll
Bentley.Civil.Geopak.Services.Geometry.Local.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.Local.2.0.dll
Bentley.Civil.GPSTrackExtCom.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GPSTrackExtCom.3.1.dll
Bentley.Civil.Help.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Help.3.1.dll
Bentley.Civil.MessageCenter.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MessageCenter.3.1.dll
Bentley.Civil.Microstation.TestUtils.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.TestUtils.3.1.dll
Bentley.Civil.Model.Tools.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Tools.3.1.dll
Bentley.Civil.MSNUnit.ECXML.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.ECXML.3.1.dll
Bentley.Civil.MX.Survey.XINCreator.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MX.Survey.XINCreator.3.1.dll
Bentley.Civil.Objects.Engine.NUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.NUnit.3.1.dll
Bentley.Civil.Objects.Engine.Nunit.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.Nunit.Model.3.1.dll
Bentley.Civil.Objects.RuleManagement.Logger.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.Logger.3.1.dll
Bentley.Civil.Objects.RuleManagement.NUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.3.1.dll
Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1.dll
Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1.dll
Bentley.Civil.Objects.UI.Coordinates.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Coordinates.3.1.dll
Bentley.Civil.Objects.UI.EntryTests.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.EntryTests.3.1.dll
Bentley.Civil.Preferences.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Preferences.3.1.dll
Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0.dll
Bentley.Civil.ProjectSettings.Presentation.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Presentation.3.1.dll
Bentley.Civil.RoadwayDesigner.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.RoadwayDesigner.3.1.dll
Bentley.Civil.Solids.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.3.1.dll
Bentley.Civil.Solids.PlugIn.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.PlugIn.3.1.dll
Bentley.Civil.Solids.Plugin.MSNUnit.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.Plugin.MSNUnit.3.1.dll
Bentley.Civil.Surface.DemToDtm.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Surface.DemToDtm.3.1.dll
Bentley.Civil.UI.CursorPrompt.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.CursorPrompt.3.1.DLL
Bentley.Civil.UI.ControlBinders.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.ControlBinders.3.1.dll
System.Design
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Bentley.Civil.Visualisation.Exporter.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Visualisation.Exporter.3.1.dll
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/plugins/Bentley.Civil.RoadwayDesigner.DLL
Bentley.Civil.Commands.CivilFilter.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Filters/Bentley.Civil.Commands.CivilFilter.3.1.dll
Bentley.Civil.DTM.Services.MX.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.DTM.Services.MX.2.0.dll
Bentley.Civil.Geometry.Services.MX.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.Geometry.Services.MX.2.0.dll
Bentley.Civil.MX.ModelFile.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.ModelFile.2.0.DLL
Bentley.Civil.MX.Interop.MXDrainage
    Assembly Version: 1.7.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.MXDrainage.dll
Bentley.Civil.MX.Interop.StdType
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.StdType.dll
Bentley.Civil.MX.Interop.VBA
    Assembly Version: 6.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.VBA.dll
Bentley.Civil.MX.StyleSetReader.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.StyleSetReader.2.0.dll
Bentley.Civil.MX.Surface.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Surface.2.0.dll
AxSHDocVw
    Assembly Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/AxSHDocVw.DLL
SHDocVw
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/SHDocVw.DLL
Bentley.Bedrock.Redistributable
    Assembly Version: 1.0.3152.28781
    Win32 Version: 1.0.3152.28781
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Bedrock.Redistributable.DLL
System.Web.Services
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Bentley.Civil.Geometry.Utilities.ClashDetection
    Assembly Version: 8.11.0.3
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.ClashDetection.dll
Bentley.Civil.Geometry.Utilities.Drawing
    Win32 Version: 8.11.0.3
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.DLL
Bentley.Civil.Subsurface
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Subsurface.dll
System.Data
    CodeBase: file:///C:/windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Bentley.Hyd.CatalogServices
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.5420 built by: Win7SP1
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Bentley.Hyd.CatalogServices.Model
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.Model.dll
Bentley.Hyd.CP.Core
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.Core.dll
Haestad.Domain
    Assembly Version: 8.11.5.5
    Win32 Version: 8.11.5.5
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DLL
Haestad.Framework
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.DLL
Haestad.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.DLL
Haestad.Drawing.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Domain.DLL
Haestad.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Mapping.DLL
Bentley.Hyd.CP
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.dll
Haestad.Framework.Windows.Forms
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.DLL
Haestad.MicroStation.Support.ViewAttributesDialogAddon
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL
Haestad.Drawing.Control
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Control.DLL
Haestad.LicensingFacade
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicensingFacade.DLL
Bentley.Hyd.Haestad
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.dll
Haestad.Support.NumericalMethods
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.NumericalMethods.DLL
Haestad.Domain.StormSewer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.StormSewer.DLL
Haestad.StormSewerProduct
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewerProduct.DLL
Haestad.StormSewer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.DLL
Bentley.Hyd.Haestad.ProductUpdate
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.dll
DevExpress.Charts.v9.1.Core
    Assembly Version: 9.1.4.0
    Win32 Version: 9.1.4.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Charts.v9.1.Core.dll
DevExpress.Data.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Data.v9.1.dll
DevExpress.Utils.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Utils.v9.1.dll
Accessibility
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
DevExpress.XtraBars.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraBars.v9.1.dll
DevExpress.XtraEditors.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraEditors.v9.1.DLL
DevExpress.XtraCharts.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraCharts.v9.1.dll
System.Web
    CodeBase: file:///C:/windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
DevExpress.XtraNavBar.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraNavBar.v9.1.dll
DevExpress.XtraPivotGrid.v9.1.Core
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.Core.dll
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.dll
DevExpress.XtraPrinting.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPrinting.v9.1.dll
DevExpress.XtraTreeList.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraTreeList.v9.1.DLL
DevExpress.XtraRichEdit.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraRichEdit.v9.1.DLL
DevExpress.XtraReports.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraReports.v9.1.dll
DevExpress.XtraVerticalGrid.v9.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraVerticalGrid.v9.1.DLL
DWNetworkParser
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DWNetworkParser.dll
Haestad.Calculations.Dynamic
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.dll
Haestad.Hydraulics
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Hydraulics.DLL
Haestad.Domain.ModelingObjects.Dynamic
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.DLL
Haestad.Calculations.Dynamic.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.Domain.dll
Haestad.Calculations.StormSewer.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.DLL
Haestad.Calculations.Scada.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.Domain.DLL
Haestad.Calculations.PondPack.OutputReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.OutputReader.DLL
Haestad.Calculations.Scada.ScadaReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL
Haestad.Calculations.GravityDerived
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GravityDerived.dll
Haestad.Calculations.GVFOutputReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFOutputReader.dll
Haestad.Calculations.StormSewer.OutputReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL
Haestad.Calculations.GVFSolver
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFSolver.dll
Haestad.Calculations.HHSolver.DataObjects
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.dll
Haestad.Calculations.HHSolver.DataObjects.VB
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.VB.DLL
Microsoft.VisualBasic
    Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.dll
Haestad.Calculations.HydrologyHydraulics
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HydrologyHydraulics.dll
Haestad.Calculations.PondPack.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.Domain.DLL
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.DLL
Haestad.HydrologyHydraulics
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydrologyHydraulics.DLL
Haestad.Calculations.Pressure
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.dll
Haestad.Calculations.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Support.DLL
Haestad.Calculations.Pressure.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.Domain.dll
Haestad.Domain.ModelingObjects.Water
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL
Haestad.Calculations.Pressure.FlushingResultsReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.FlushingResultsReader.dll
Haestad.Calculations.Pressure.MSX
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.MSX.dll
Haestad.Calculations.Pressure.ResultsReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.ResultsReader.dll
Haestad.Calculations.SewerCAD
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.dll
Haestad.Calculations.SewerCAD.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.Domain.dll
Haestad.Calculations.SWMM5.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL
Haestad.Calculations.SewerCAD.OutputReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.OutputReader.dll
Haestad.Calculations.StormCAD
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.dll
Haestad.Calculations.StormCAD.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.Domain.dll
Haestad.Calculations.StormDerivedEngine
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormDerivedEngine.dll
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.dll
Haestad.Calculations.SWMM5.OutputReader
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.OutputReader.dll
Haestad.CanvasLibrary.Drivers.GDI
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Drivers.GDI.dll
Haestad.CanvasLibrary.Framework
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.DLL
Haestad.CanvasLibrary.Framework.Windows.Forms
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.dll
Haestad.Domain.AceDaoInterop
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.AceDaoInterop.dll
Haestad.Domain.DaoInterop
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DaoInterop.dll
Haestad.Domain.DataExchange
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.dll
Haestad.Domain.DataExchange.IModel
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.dll
Haestad.Domain.DataExchange.IModel.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Support.DLL
Haestad.Domain.DataExchange.IModel.Forms
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.dll
Haestad.Domain.DataExchange.IModelPlugIn
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModelPlugIn.dll
Haestad.Domain.DataObjects
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.dll
Haestad.Domain.DataObjects.Water
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.Water.dll
Haestad.Domain.LibraryObjects
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.dll
Haestad.Domain.LibraryObjects.Install
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.Install.dll
System.Configuration.Install
    CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Haestad.Domain.ModelingObjects.PondPack
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.PondPack.dll
Haestad.Domain.SUE
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.SUE.dll
Haestad.Drawing
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.DLL
Haestad.ProjectWiseFacade
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ProjectWiseFacade.DLL
Haestad.Framework.Windows.Forms.Reporting
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL
Haestad.Framework.Windows.Forms.XtraReports
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL
Haestad.GraphicsLibrary.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.Support.DLL
Haestad.DrawingStorage
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DrawingStorage.dll
Haestad.DWNetworkParserBuilder
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DWNetworkParserBuilder.dll
Haestad.Dynamic.DataExchange.CivilStorm
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Dynamic.DataExchange.CivilStorm.dll
Haestad.Schema.DataExchange
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Schema.DataExchange.DLL
Haestad.FileParser
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.FileParser.dll
Haestad.Framework.Windows.Forms.Divil
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Divil.dll
Haestad.Framework.Windows.Forms.Steema
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Steema.dll
Haestad.Framework.Windows.Forms.Syncfusion
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Syncfusion.dll
Haestad.GeoPAK
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GeoPAK.dll
Haestad.GraphicsFileLibrary.RasterFileLibrary
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.RasterFileLibrary.dll
Haestad.GraphicsFileLibrary.VectorFileLibrary
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.VectorFileLibrary.dll
Haestad.Shapefile
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Shapefile.DLL
Haestad.GraphicsLibrary.GDI
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.dll
Haestad.GraphicsLibrary.GDI.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.Support.dll
Haestad.GraphicsLibrary.OpenGL
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.OpenGL.dll
Haestad.HydraulicReviewer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydraulicReviewer.dll
Haestad.InRoads
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.InRoads.dll
Haestad.LicenseAdministrator.Library
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicenseAdministrator.Library.dll
Haestad.LoadBuilder.Calculations
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.dll
Haestad.LoadBuilder.Calculations.Sewer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.Sewer.dll
Haestad.LoadBuilder.Calculations.SewerCAD
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerCAD.dll
Haestad.LoadBuilder.Calculations.SewerGEMS
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerGEMS.dll
Haestad.LoadBuilder.Data
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Data.dll
Haestad.LoadBuilder
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.dll
Haestad.LoadBuilder.StormSewer
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.StormSewer.dll
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.dll
Haestad.ModelBuilder
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.dll
Haestad.ModelBuilder.Support
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Support.DLL
Haestad.ModelBuilder.Forms
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Forms.dll
Haestad.MX
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MX.dll
Haestad.Network
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Network.dll
Haestad.NetworkBuilder
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.NetworkBuilder.dll
Haestad.RealDWG.Interop
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.RealDWG.Interop.dll
Haestad.SCADA.Domain.Application
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.Application.dll
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.DLL
Haestad.SCADA.Domain.HOPC
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.HOPC.dll
Haestad.SCADA.Domain.OPC
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.OPC.dll
OpcDaNet
    Assembly Version: 9.0.1.0
    Win32 Version: 9.0.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcDaNet.DLL
Haestad.SCADA.Forms
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Forms.dll
Haestad.ScenarioComparison
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.dll
Haestad.ScenarioComparison.Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.Domain.dll
Haestad.Sewer.DataExchange
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.dll
Haestad.Sewer.DataExchange.IModelPlugIn
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.IModelPlugIn.dll
Haestad.SQLite
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLite.dll
Haestad.SQLiteConverter.Core
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLiteConverter.Core.dll
Haestad.Storm.DataExchange
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Storm.DataExchange.dll
Haestad.Water.Forms
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.Forms.DLL
TeeChart
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.DLL
Haestad.StormSewer.SQLiteConverter
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.SQLiteConverter.dll
Haestad.Support.LandXML
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.LandXML.DLL
Haestad.Subsurface
    Assembly Version: 8.11.9.163
    Win32 Version: 8.11.9.163
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Subsurface.dll
Haestad.SUE.CP.ContentManagement
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.ContentManagement.dll
Haestad.SUE.CP
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.dll
Haestad.SUE
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.DLL
Haestad.SUE.CP.Model.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Model.3.1.dll
Haestad.SUE.CP.Presentation
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Presentation.dll
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandBar.DLL
Haestad.Support.Mixed
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.Mixed.dll
Haestad.SurfaceModeling.Interop
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SurfaceModeling.Interop.dll
Haestad.TerrainExtractor
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.TerrainExtractor.dll
Haestad.ThiessenPolygon
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.dll
Haestad.ThiessenPolygon.Engine
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.Engine.dll
Haestad.UserDataExtensions
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.UserDataExtensions.dll
Haestad.Water.DataExchange.Controls
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.DataExchange.Controls.dll
hmimsdascnet
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/hmimsdascnet.dll
IModelEngineAddIn
    Win32 Version: 08.11.07.63
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/IModelEngineAddIn.dll
Ionic.Zip
    Assembly Version: 1.9.1.8
    Win32 Version: 1.9.1.8
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Ionic.Zip.dll
Microsoft.Data.ConnectionUI.Dialog
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.Dialog.dll
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.DLL
MoreLinq
    Assembly Version: 1.1.17511.0
    Win32 Version: 1.1.17511.618
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/MoreLinq.dll
OpcHDAWrapper
    Win32 Version: 6.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcHDAWrapper.dll
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandDock.dll
TeeChart.Languages
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.Languages.dll
Washington
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.dll
Washington.MicroStation.CP
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.MicroStation.CP.dll
    Win32 Version: 08.11.09.832
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.DLL
Bentley.MicroStation.Templates.Support.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.MicroStation.Templates.Support.resources.DLL
Bentley.DTM.ElementTemplate
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DTM.ElementTemplate.DLL
Bentley.DTM.Element.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DTM.Element.resources.DLL
Bentley.MicroStation.GeoCoord
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.GeoCoord.DLL
publishdgn
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/publishdgn.DLL
PublishDgn.Interfaces.Transformation
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/PublishDgn.Interfaces.Transformation.DLL
bentley.publish
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/bentley.publish.DLL
TransformationControls
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/TransformationControls.DLL
publishdgn.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/publishdgn.resources.DLL
Bentley.RSS
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.DLL
GCSDialog
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/GCSDialog.DLL
PrintPrep
    Win32 Version: 08.11.09.713
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PrintPreparation/bin/PrintPrep.dll
Bentley.ExtensionDiscovery
    Win32 Version: 08.35.01.06
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL
Bentley.MicroStation.ECIntegration
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL
Bentley.GeorasterECPlugin
    Win32 Version: 08.11.09.105
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.GEORASTERECPLUGIN.dll
Bentley.BaseSQLPlugin
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL
Bentley.EC.SQLAdapter
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL
Bentley.EC.SchemaMappingSQLBuilder
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL
Bentley.DgnECPlugin3
    Win32 Version: 03.10.01.01
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/POWERGEOPAK/CIVILPLATFORM/DESIGNSYNC/BENTLEY.DGNECPLUGIN3.dll
Bentley.ConfigurableECPlugin
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.ConfigurableECPlugin.DLL
Bentley.Descartes
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.DESCARTES.dll
Bentley.RasterManager
    Assembly Version: 1.0.0.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterManager.DLL
Bentley.Civil.Geometry.Services.InRoads.3.1
    Win32 Version: 08.11.09.878
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/Bentley.Civil.Geometry.Services.InRoads.3.1.dll
Bentley.DGNECPlugin.Common.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DGNECPlugin.Common.resources.DLL
Bentley.MicroStation.WinForms.Docking
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL
Bentley.Civil.LandXml.3.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/DTMLink/Bentley.Civil.LandXml.3.0.dll
Bentley.ECSystem.2.0.resources
    Assembly Version: 2.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECSystem.2.0.resources.DLL
Bentley.Windowing.Win32
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL
bentley.designexplorer.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.resources.DLL
Bentley.Internal.RealDwg
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Internal.RealDwg.DLL
Bentley.Windowing.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.Windowing.resources.DLL
Bentley.Geometry.Convert.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Convert.2.0.DLL
Bentley.EC.Controls.2.0.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.EC.Controls.2.0.resources.DLL
Bentley.RSS.Common
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.Common.DLL
Bentley.TaskNavigation
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.TaskNavigation.DLL
Bentley.TaskNavigation.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.TaskNavigation.resources.DLL
Bentley.UI.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.UI.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
