Each time I open a project I have to reload all surfaces.
Say I have a project called Alpha. I load 12 surfaces, work for a day, save project and all surfaces then get out.
Next time I open it I have to load all surfaces again, one at a time.
I'd like to already have them loaded, or still loaded when I return.
What levers aren't I pulling?
Thanks in advance
Are you using an RWK file? If so, what is in it?
I have an RWK that loadssomewhere around 10 surfaces, one ALG, one ITL and one IRD and it works perfectly.
Yes, a RWK project file.
When I view it with a text editor all thats in it is the preference file that I use.
I just took 3 minutes and loaded 5 ALG files into it and saved the project as TEST.
(So thats 3 surfaces, 1 XIN and 5 ALGs.....Edit the RWK file called TEST witjh a text editor and
still, all that it contains is the XIN
This is whats in it
RWK
XIN K:\C-Civ\0000\InRoads\Preferences\kitimat model.xin
All of the files that you loaded won't save to the project .rwk automatically. Did you click on the Project Options (Under Save As) and check the add buttons next to these files?
Chris
DOH!!
Thanks much
