Hi all,
Good to see ORD Update 3 is released. However, when using Training and Examples workspace and Training-Imperial workset, no Bentley feature definitions are shown in the Libraries of Explorer. It was available in Update 1 but not in Update 2 and 3.
When checking the Settings, Configuration Variables and Edit Configuration Variables windows, the following lists show:
in Libraries of Explorer, no Bentley's training and example feature definitions are available. Please see the screenshot:
Any feedback is highly appreciated.
Charley
Beginning in Update 3, the "OpenRoads Training" example workspace was re-named to "_Civil Default Standards - Imperial", so if you are using a workspace that you customized in Update 2, you will want to look at the "Workspace Updates.pdf" document delivered in the "C:\ProgramData\Bentley\OpenRoads Designer CE\Configuration\Organization-Civil" folder.
Thanks for your reply Kevin. I created a Test workset under Imperial Standards workSpace but Bentley delivered feature definition is not available in Library in Explorer. I am trying to use delivered base standard ORD feature definition, which is available in Update 1. I cannot get it since Update 2 and now Update 3.
