Why is there a name field in the super editor and why is it always off just slightly form the assigned transition stations?
Each point in the diagram is stored along with its settings (Type, Contraints, etc..), so the name is simply a way to give each point a unique designation. The rounding on the name is a mystery to me as well. If it causes too much confusion, you can turn the column off or move it to the end of the table.
Answer Verified By: John Harvey
