I would like to create cross sections in specific chainagas, I wouldn't do it one by one, so I put list of values to text file and try to use ASCi option Problem is I created few sections as on file, but I can't see terrain model line in that profiles.
Could anybody write me how should look proper .soe file to import into ?
Also I noticed it is not set so I can't update this cross sections. I think it should work as normal lcross sections set.
Thanks in advance, Pawel
What software are you using?
Railtrack SS2, but I have also SS4 if there better solution
