I have created alignment through element method. When I draw the profile from analysis > create profile it shows same level for existing and design level. Can an one help me.
Thanks!
Edit the 'Indian Profile 1000.mxtip' file - it probably has existing ground listed twice.
Hello Santosh,
Try generating profiles using the option of Add-Ins - Longsection. This option will create profile with more options and less errors. Secondly the tip file you are using now needs to be modified from the existing ground to design surface.
Hi Dipak,
Can you tell me how to make changes in tip file?
Thanks in advance
Santosh Rai, EngTech MICE, ACP, BQT
Senior Designer - Highways
Attached is the screenshot as required.
Alternative I suggest you to use the option of Add Ins --> Long Sections. I personally find this option for profiles more effective.
Answer Verified By: Santosh Kumar Rai
Thanks Dipak!
